Update on the nissan cam chain noise
the-lada-dude, Feb 8, 5:08pm
well i had a dig around inside the engine and found the upper chain tentioner was seized. and worn badly, which then moved on to being broken bits ofthe rubbing pad.
i can't locate one for the life of me, any of you chaps got a stuffed engine we can nick the part outa !
nissan GA 15 dohc 1996
morrisman1, Feb 8, 5:12pm
hmm, I have one sitting here from a 97 ga16de. Not much wear.
You can get the timing chain kits through partsmaster which come with the whole lot.
mantagsi, Feb 8, 5:48pm
is it just me or is this one hell of a common problem with these GA15DEs
morrisman1, Feb 8, 6:18pm
Many GA series engines are getting up around the milage where these parts are wearing out so naturally there will be a few around which need them replaced. A bit like wheel bearings and suspension bushes.
It is not so much a design flaw but more of a wear and tear issue, perhaps it would have been better to use a idler gear as a tensioner
the-lada-dude, Feb 9, 6:17am
i thought these little eng were bullet proof !
but i must admit that chain tensioner is a poxy system.
it's also frustrating that( A )the customer doesn't want to spend
money
( B ) there are probably lots of U/S eng's around
( C ) i cant find any, and it's hard to to justify the time looking for one
if i was desperate i could adapt another rubbing block to the unit, but that just becomes a nightmare.
i might come back to you MORRIE M and see if you might part with your old one
mm12345, Feb 9, 6:51am
Nissan parts customer service can be a PITA at times.
Sometimes they don't seem to be able to locate the part number for an individual part, only a complete kit, but if you can give them the part number, then they can locate it on their system.(Recent example I had was panhard bushes for my old safari/patrol.Nissan NZ insisted that I need an entire panhard rod with bushes for $600+.Through help on a forum, I get the part numbers, give those to Nissan, they have stock in NZ, and cost was only about $12 for one and $18 for the other.)
I've got a pdf FSM for GA16DE (US Sentra).Tensioner is probably identical for GA15 and GA 16DE models.Morrisman's part will probably work for you.
Crapped out tensioner is probably from slack servicing - lack of oil changes.I have a GA15DE here with 200,000km, still runs very sweet and quiet.Have had other issues (oil leaks/AFM/distributor), but in general these do seem to be bullet-proof motors.
morrisman1, Feb 9, 9:17am
Its about $160 to buy a new top tensioner from nissan, pretty pricey considering you can get the whole kit including chains, tensioners and oil seals from partsmaster for under $200
My old sentra is about to tick over 300,000km and Ive had a look at the tensioner and its fine although has grooves about 2mm deep from chain wearing on it, that is perfectly acceptable wear in my books.
I also know of a ga14ds which drank some water and bent all the conrods. There is probably still a tensioner on there but the engine was dismantled to see what damage was done so no guarantees and I cant get anything off it straight away
the-lada-dude, Feb 9, 11:50am
i've been banging on at a wrecker for 3 days now, recons he will have one
some where, he's got 1/2 hr left then i think i'll give up,
if i dont have any luck, do you want to sell that tensioner MM ! if so we can set up an auction.
the-lada-dude, Feb 9, 12:18pm
the wrecker recons they have found one !
says it should be in my hot little hand tomorrow, w'ell see.
ta MM
