Light turns off after 90 secs but cant get warrant cause of lightwont turn off straight awayAnyone have thetool thatswitches off airbag light pl orwhere you can get one.
redmouse,
Feb 28, 10:49am
Hammer!
sharchew,
Feb 28, 10:53am
Get the Mechanic to reset it he should have the gear at his workshop if he is a good Mechanic.
saxman99,
Feb 28, 10:54am
If a fault remains the light will not behave even after a reset, you need to rectify the fault.
carmedic,
Feb 28, 10:54am
+1 I can??
attitudedesignz,
Feb 28, 12:20pm
OP, check the web for a "car medic"(remove the space) in Napier, i'm sure he could help.
Dash pulls out wit two screws, pull bulb out, take ya five mins
pup2,
Feb 28, 12:56pm
WOF fail as light doesn't come on
elect70,
Feb 28, 2:39pm
Look at unuthoirised BMWtells how to make own resettoolsorwhich pins to bridge,site is full of good info for DIY BMW owners
carmedic,
Feb 28, 2:49pm
Link! However,I think you??
shadowzz,
Oct 27, 12:18pm
Will this do the job! Listing #: 526816083
jmma,
Oct 27, 3:06pm
Thread from Feb, think the job might be done by now (o:
shadowzz,
Oct 27, 3:39pm
Nah! It'll have to be done again and again on every BMW in the country until they taken to pickapart. Maybe we should be able to borrow a reset tool from the library or video shop, since BMW intends to charge $50 a reading, from a device that cost $12 to make in China.
raymond00001,
Oct 27, 4:09pm
Just wire the light in paralell with one of the circuits that is not faulty
carclan,
Oct 27, 5:59pm
Try a fire axe, but be careful as if you miss air bag light you might hit the oil pressure light.
carclan,
Oct 27, 5:59pm
Try a fire axe, but be careful as if you miss theair bag light you might hit the oil pressure light.
shadowzz,
Oct 29, 11:52am
I had a warning light not showing so I removed the instruments to check the bulbs. I didn't want to take off the steering wheel so I pulled the instruments through the wheel, but as I turned the wheel it locked the steering. To unlock the steering Ihad to reconnect the battery which because the dash was out signaled a fault in the SRS. So now to get a warrant I must 1. pay $50 for a reset 2. pay $65 for a reset tool 3. parallel wire the SRS light to one of the other lights by removing the instruments again. 4. operate the light with a remote switch. or 5. operate the car without a warrent or registration or insurance.
2.
chebry,
Oct 29, 12:04pm
Bavarian money waster true to label
persh,
Nov 1, 6:26pm
How about actually spending some money and fixing the airbag fault - it may save your life! Or is your life or the lives of your family not worth that!
shadowzz,
Nov 26, 2:40pm
There is no airbag fault. The fault light was triggered by turning the steering lock when the dash was out but the battery was connected.
carclan,
Nov 26, 2:51pm
Better just to take it to BMW or buy the tool, saves alot of hassle
shadowzz,
Nov 30, 6:32pm
Nah hit it with a truck, turns off all the lights.
