Wl-t mazda 2.5
faybian, Apr 6, 5:23pm
could any one tell me what sequence to set the valve clearances and what the clearances are thanks
faybian, Apr 6, 7:31pm
any 1
jmma, Apr 6, 7:36pm
budgel, Apr 7, 7:43am
Jmma's figures are correct for the 2.5, if you cant take it from there maybe you should pay someone else to do it. There is a downloadable link with a diagram there.
Measurewhenthe back of the cam opposite the lobe is facing the rocker arm. measure between the cam and the rocker arm as per the diagram.
ceebee2, Apr 7, 10:40am
As per budgel, if you haven't done it before then leave it to a COMPETENT Mechanic as it can caus all sort of probs not done exactly as per standard practice. i.e burn valves/ lose power.
