Battery or charging issue.
littlebuckrat, Apr 22, 8:58am
Is there a easy way to test stuffed battery/alternator!
alan1111, Apr 22, 9:08am
Flat battery i presume !
The battery light on the dash does it go out when you start the car up. If does not probably alternator but my advice is go to a mechanic and get it checked out.
tonyrockyhorror, Apr 22, 9:19am
Yes. It's easy when you know how.
littlebuckrat, Apr 22, 9:52am
pretty confident itll be the battery as everythings running good lights bright etc when its started just not enough juice to start her from cold
andy61, Apr 22, 10:12am
Sounds like battery
intrade, Apr 22, 11:15am
does it start fine when you add jumper cables!
johnf_456, Apr 22, 11:20am
Get a cheap multimeter and measure the voltage when engine is running.
petermcg, Apr 22, 11:44am
What sort of car is it
msigg, Apr 22, 12:05pm
Just rev it with the head lights on, if it goes brighter then your charging is ok. Its the battery.
bigfatmat1, Apr 22, 2:25pm
This does not work on most vehicles. op take to auto sparky most will check for free espicially if its ya batt and you buy from them which is also probably cheaper than supersheep or repco.
tonyrockyhorror, Apr 22, 2:33pm
Fully charge the battery then test the battery voltage when cranking for 10 seconds. Disable the fuel or ignition so it doesn't start.
It's almost certain to be the battery. First cold snap always kills the marginal ones.
cassandra13, Apr 22, 4:06pm
marshell or any auto sparky can do a simple load test on the battery. done.
planespotterhvn, Apr 22, 4:53pm
Can be shagged starter bearings which give the exact symptoms of a stuffed battery.take to auto electrician and they can do some quick tests.
littlebuckrat, Apr 22, 5:12pm
To late its got a new battery. Its a diesel hilux seems the battery just holding charge according to my engineerman
tonyrockyhorror, Apr 22, 7:25pm
It's called a surface charge. There's no delivery capacity behind it.
littlebuckrat, Apr 22, 9:08pm
not reall worried what its call batterys stuffed so down the hole it goes
tonyrockyhorror, Apr 22, 10:39pm
So you're not keen on learning anything in order to help yourself in the future. Your loss.
