Looking at buying a hyundai van. always had petrol in the past. so how many km between services and what is the approx cost!
NZTools,
May 4, 6:59pm
What year Hi-and-dry! it makes a difference.
triangle1,
May 4, 7:03pm
This is a 2011 model.
NZTools,
May 4, 7:07pm
15,000 kms or 12 months. Whichever comes first
triangle1,
May 4, 8:07pm
OK and what does it cost !
jasongroves,
May 4, 8:17pm
For a full service! Or just an oil and filter change! Or.!
cuda.340,
May 4, 8:18pm
15k! wow thats almost double whats in the toyota handbook & 5k more than the Mazda/Ford.
May 4, 8:20pm
Some diesels have much higher service intervals than 15k.
May 4, 8:21pm
Not much if it's done once a year.
triangle1,
May 4, 8:22pm
I know next to nothing about diesels. what are the costs for both!
jasongroves,
May 4, 8:24pm
What model and engine!
triangle1,
May 4, 8:25pm
It is a hyundai van.not sure of engine size but takes a 1100kg payload.
May 4, 8:26pm
For a basic service, allow $250. Have you actually got the van!
triangle1,
May 4, 8:28pm
Not yet but am looking at 1 and hope to get it in next few days. It has approx 1300k on clock and they want $40 000. It is an automatic
May 4, 8:31pm
OK, in that case, you might want to consult your Hyundai dealer. Some dealers offer free servicing for X number of years + they might be able to help you out with all the service costs and requirements.
triangle1,
May 4, 8:32pm
OK thanks for that. sounds good advice and can be part of the haggling
jasongroves,
May 4, 8:34pm
Is it on TM! Do you have the rego number! It should still be under warranty, which I will assume is transferable! If that's the case, there may be specifics in the warranty that require the use of certain workshops and/or recommended parts brands.which could make things more expensive. Basic oil change including 5-6L of oil and a filter would start at $100-$120 at somewhere like Oil Changers. There really are a lot of variables.
triangle1,
May 4, 8:35pm
Thanks Jason. soit does not seem more expensive than a petrolvan.in fact is cheaper!
May 4, 8:40pm
A petrol engine is usually cheaper to service, but it also depends on what engines you're comparing. Keep in mind that licencing costs nearly $600 a year for a diesel van + RUCs.
triangle1,
May 4, 8:40pm
Hyundai seem popular I have seen a lot of different models lately. Are they reliable!
May 4, 8:42pm
Honestly, I have no idea. But, Hyundai has come a long way, not cheap and nasty like they used to be.
triangle1,
May 4, 8:45pm
will get interior fitted out by Van Xtras in auckland.
May 4, 8:47pm
Are you self employed!
triangle1,
May 4, 8:47pm
yes. why do u ask!
May 4, 8:53pm
I ask as servicing costs suddenly become lower as you can claim GST, but you already knew that.
