How do u clean diesel injectors
kevlight, May 17, 9:38am
how do you clean diesel injectors on aturbodiesel ute 2litre
ford courier 2003
ute is getting harder to stat andruns rough
m16d, May 17, 9:43am
Are the glow plugs working.!
kevlight, May 17, 9:55am
thats a good point, had them changed two years ago ,i suppose the could be blocked up or faulty by now , can they be cleaned or do they need to be replaced !
a.woodrow, May 17, 9:57am
Test you glow plugs first, that would be the first point of call before you worry about injectors. To answer your original q, most diesel specialists can clean or rekit injectors far cheaper than replacing.
mugenb20b, May 17, 3:53pm
2 years ago! They usually last 6 to 12 months in Mazdas. Test each one, and if one is faulty, replace the lot. They are not servicable, but get a drill bit the same sizeas the heating element end of the glow plug and run it down each hole with your hand. That will clean out any carbon in the tubes, otherwise you may damage the new glow plugs when fitting them.
Also, put some anti-seize grease on the threads before you fit new glow plugs and don't overtighten them.
And, while you've got your tools out and you're all enthusiastic, replace your fuel filter. It's on the driver's side inner mudguard, behind the battery.
next-to-normal, May 18, 12:36pm
moreys diesel additive in the fuel is got good wraps,supercheap got them $23,see if its starts better on a newer battery to,
