Hiace help please
zeekay, Jun 5, 9:05am
1997 2.8 diesel Hiace van. Turn key to start and sometimes I just hear a click. Release key and then try again and it engages the starter motor and goes. What is the problem and the fix please.
johnf_456, Jun 5, 9:18am
Check your battery connections, they must be clean and tight.
carmedic, Jun 5, 9:26am
^ or the contacts in starter need replacing.
zeekay, Jun 5, 9:30am
Thank you both and will do as has been suggested.
ceebee2, Jun 5, 2:57pm
If you get stuck, "tap" the starter body with a hammer or similar (NOT the little solenoid) and it will get you to the garage to have the starter brushes replaced cos they are nearly worn out.
muzz67, Jun 5, 6:49pm
starter contacts,, easy to replace yourself. pull the old knackered ones out, take them and every serial or part number you can find to repco. parts less than $50, Garage will charge$400
carmedic, Jun 5, 7:12pm
VERY unlikely its brushes in those Denso starters, it WILL be the contacts; they??
zeekay, Jun 6, 8:24am
Hey all. Took 2 auto sparky. Removed starter motor. He replaced contacts. I re-installed s/motor and away sweet as. $56.54 + tip of .46 cents. Thanx.
