2009 calais v6 sportwagon problems
cccc3, Jul 12, 4:22pm
Hi, has anyone had an electical problems with this model!
cccc3, Jul 12, 5:37pm
The modules come awake at night time when everything is turned off, so of cause the battery goes flat.
bigfatmat1, Jul 12, 6:39pm
Loom plug left hand pillar moisture is a common cause of this. They also had software faults causing batt drain faults.
cccc3, Jul 12, 7:30pm
the modules have been replaced. I wouldnt think it would be a moisture problem as my car is in a garage.How do i know if this is an on going problem!
cccc3, Jul 12, 7:34pm
Or is this a common problem !
bigfatmat1, Jul 12, 7:40pm
its a common problem would not matter if car is in garage unless you never drive it or avoid all damp raining days swerve for puddles and never wash your car.
cccc3, Jul 12, 7:50pm
Thanks for your reply. I am very annoyed that I bought this car new 4 years ago and have this problem with it not being reliable, 4 times I have had the car not starting (no electrices), It as gone back to the holden garage that I bought it from, but all they do is patch up something.
clark20, Jul 12, 7:54pm
The software should have been done by 2009, is it still serviced by Holden!
Also is it a V8! They need the DIN65 battery instead of the DIN55, it helps a lot.
cccc3, Jul 12, 7:59pm
yes still serviced by holden & v6
cccc3, Jul 12, 8:04pm
but i did buy an extended warranty(sp) Im very disappointed to have bought myself a nice new car that is unrelyable. It has beeen 4-5 times now that my car hasnt started now.
neo_psy, Jul 12, 8:16pm
Take it to a different Holden dealer - I had no end of trouble with some dealers.
cccc3, Jul 13, 6:10am
ok I will try another dealer.
