Ive just got a ford v6 engine but not sure what size the casting number is 2721E ive googled with no avail.the carb on the other hand comes back as a IV zodiac 40dva2 but doesnt look to becorrect for this engine engines got three exhast port and guessing its also a D port going by the inlet gasket that came with it.
jmma,
Jan 7, 5:27pm
2.5 V6 1965-72
gt_escort,
Jan 7, 6:57pm
thats a bugger was hoping it was a 3L .was the 2.5 a good engine!
jmma,
Jan 7, 7:11pm
Don't know, I'm a Holden man, hopefully a Ford man will be along shortly(o:
pfemstn,
Jan 8, 8:01am
blocks the same! more likely to be 3 litre late model if its got d shaped ports ie post 1972
gt_escort,
Jan 8, 1:19pm
Yep she a 3L was cleaning the block of all the years of grim and stamped on a lag close to the fuel pump is 3.0 .thanks guys for the help
ian86,
Jan 8, 2:23pm
What are you doing with the motor!., many moons ago when I was a young fella I had a MK1 cortina with a V6 in it., it was a common transplant back then. it went well too from what I recall.
