I have owned my 2004 3.0R B4 Legacy for around 6 months with no real issues, but after a 40-minute drive in heavy rain this morning the check-engine, traction control and cruise control lights started flashing. I also noticed a slight pulsing in power (barely noticeable) for around 20 minutes before the lights came up.
Has anyone had this issue, or know what it may be! I plan on getting a diognostic report, but thought I'd try to find some free info first :p
Thanks, Mike
hondalova,
Jul 16, 3:20pm
sounds a bit like alternator related. best to get it checked at auto sparkie.
jinx317,
Jul 16, 4:28pm
My guess would be air/fuel ratio sensor, need to have the engine scanned to check fault codes, the sensors arent cheap around the $600 mark + GST
neo_psy,
Jul 16, 4:34pm
Quick way would be go to a dealer and get them to scan the error codes. You can probably do it yourself if you google it.
bigfatmat1,
Jul 16, 4:55pm
sounds like a fault in traction control/abs system as above for a more accurate diagnossis codes will need to be read
tinker1,
Jul 17, 6:29pm
Yep take it to an auto sparky or someone with scan tool and more than likely an air/fuel ratio sensor.
