No park lights Nissan Prarie Joy 1996
kdh1947, Aug 31, 4:28pm
Can anybody help with the fuse number on the Asian written fuse box as the headlamps and stop lamps work well but no front or rear parks or dash lamps.
A link to a wiring diagram would be awesome.
Have Autodata at work but no Prarie on it and have no idea what it would be called in Europe.
TIA Ken
r15, Aug 31, 4:38pm
try checking all the fuses, there wont be more than 50, and its not difficult to check them
andrea_w, Aug 31, 5:31pm
Don't pull them out 1 by 1. Get a test light, you can check a complete fuse box in 30 seconds.
Fuses blow for a reason, you need to find out why it blew, fix the fault then replace the fuse.
Has a stereo been fitted recently!
kdh1947, Aug 31, 6:39pm
Have checked all known fuses for continuity, however, without knowing which fuse controls what its rather a waste, as knowing if the fuse or wire colour code is correct would answer all questions. This may not be a fuse problem but a switch fault instead. Radio fitted is a replacement but unknown when it was done.
Just purchased vehicle second hand from TM
johnf_456, Oct 12, 1:52am
As above if you have a fitted a radio recently check your headunit earth
