Do the 2007 3litre Nissan navara's hv belt or chain. Engine No: ZD30DDT-092069K
Cheers mandy
happylad3,
Sep 28, 4:15pm
The ZD30 engine is cam chain driven. 100% no doubt about it.
duanz,
Sep 28, 4:19pm
Thank ü.so no belt to worry about, chain self tightens aye.also haven't Bort vehicle yet, but as rule if its in metal case is it chain driven.! An plastic case belt!
happylad3,
Sep 28, 4:32pm
yup chain will have an auto tensioner. and yes generally if it has a plastic cover its belt. and metal have chains.
You think chains are worry free on modern Nissan diesels!Do some proper research on this first and the likely repair costs and you will be begging to have a belt back.Both the YD and ZD engines have got other nasty and expensive habits too.
xs1100,
Sep 29, 6:26am
the later model zd was fine the early one was a drama
dent,
Sep 30, 1:32pm
The zd30 also has pump issues and piston melting issues.
