Dual car stereo
thewomble1, Sep 28, 8:47pm
Is it possible to have two stereo units use the same speakers! The stereo system in car does not play MP3 discs. Want to install a unit just to play MP3 discs. Was thinking of using a multi-pin rotary switch to be able to switch the output wires to the speakers from one unit to the other unit. THANKS
gammelvind, Sep 29, 5:33am
No reason why that wouldn't work, but would the hassle be worth the effort compared to just buying and installing a new head unit, they are getting so cheap these days.
thewomble1, Sep 29, 7:27pm
Where do you put the CD in these units!
skull, Sep 29, 7:30pm
Intrade has a rather large cigarette lighter plug in mind, rather like a hubcap from a mini hanging out of your dash.
motorboy2011, Sep 29, 7:33pm
Parents van had this setup. Both head units were connected to the speakers. Using a relay, when head unit 2 was turned on, it would cut the acc power feed to head unit 1.
NZTools, Sep 29, 7:56pm
whynot just put your MP3's on a flash drive. 32g for about 35 bux, and sure as hell beats scratch cd's.
thewomble1, Sep 29, 9:23pm
Thank you.got the answer I was hoping for. Will look into fitting a relay.good thinking. I take it that both units wire to speakers. no need for a rotary switch to switch from one unit to the other. Will make installation a lot easier.
96jeep4life, Sep 30, 8:22am
Its actually more common than you think, especially with people that want to keep their factory car stereos, theres a number of audio people in auckland which i know do this, they normally fit the new one in the glove box
motorboy2011, Sep 30, 10:16am
yeah the parents setup came like it from japan. The van had a factory AM radio, and an aftermarket radio fitted under it which had FM but no AM, I think that was the reason to have 2 in there. yes both units were wired directly to the speakers as only one would ever run at a time anyway
