Diesel car won't start in the morning? Please help
Page 4 / 4
splinter67,
Oct 21, 9:04am
mechnificent wrote: Actually, just about every single thing that mm12345 said is wrong.
He didn't even read the Op correctly.[/quot
ya might want to read the last bit in his post or are you some amazing mechanic that can diagnose problems without seeing the car like all the rest of the so called mechanics on here
mopeds,
Oct 21, 9:29am
White smoke on start-up usually means leaking injectors, the fuel lines remain pressurised but if the injectors leak the impulse from the fuel pump won't open the injector. My bongo has had one leaking injector for years but fires first pop with a cloud of white smoke, not worth the expense to fix.
mechnificent,
Oct 21, 9:42am
Yes, I'm an amazing mechanic, and can diagnose faults without seeing the car. The thing is to diagnose, with tests and following through systematically and methodically. starting with the simplest things that might be causing the problem first generally.
splinter67,
Oct 21, 9:47am
so how ya gunna do these tests without seeing the car having a guess on what the problem is what everyone on here is doing
mechnificent,
Oct 21, 10:21am
Read the thread carefully and you will see what I am going to do.
splinter67,
Oct 21, 10:27am
I have read it.You are guessing at what the problem is. You cant see what the problem is you are going off a very vague description telling everyone your right when really you have no idea like the rest of us
mechnificent,
Oct 21, 12:46pm
Want to show me where I guessed anything! I suggested a test to do, the simplest test that could explain the problem. Once I hear what that did, then I'll suggest the next step.
splinter67,
Oct 21, 1:16pm
you guessed its the pump by suggesting to pump the manual pump it could be a number of things as you eluded to in post 45 the best bit of advice was by mm12345 take it to a diesel specialist read the original post look at the language used its not mechanic speak (no offense op ) offer advice but don't expect to much
mechnificent,
Oct 21, 2:38pm
What if it's an electrical fault! We can diagnose. it can be done.
mechnificent,
Oct 21, 2:39pm
Actually Splinter, don't bother, I'm not really interested in what you "think".
carclan,
Oct 21, 6:19pm
Do not use spray start as the car will become a drug addict in no time - does the qualify as help!
escapelife,
Oct 22, 11:11am
not all glow plugs are equal either repco plugs for 2.5 ford/mazda dont last long but from what has been said OP its more than likelyin the glow plug system
snoopy221,
Oct 22, 12:37pm
Sheesh it's still an *active thread*
Reading and comprehension 1 0 1
History of car. Car was great. Then car stood for a few months as it was not needed
sitting. little valve in pre-pump. anyone wanna bet their left one that poster has pumper up hard and not back here for a reason!
turbophil,
Oct 23, 7:04am
DidI miss it but has the compression been checked! the fact that it finally starts knocks and misses,blows white smoke are all caused buy low compression would have been the first thing I would do as they are bad for this at hi miles must have a least 350psi to start cold
Oct 23, 7:08am
the original poster never returned. its either low compression as mentioned with a can of compression to fix as a joke or its got a leaking fuelsystem letting air in. or its glowplugs have intermittrnd fault and i posted how to easy check if glowers work with finger on the plugs to see if they got warm.
