Hi I have a mazda b2200 f8 2.2l 12 valve soch engine and am having a problem with the water.
I have changed the head gasket, inlet gasket and thermostate and still have a problem with the presure build up in the radiator. have a slight leak in the inlet manifold but think the gasket didnt seal properly, going to glue the gasket up tomorow and see what happens. All i can think of now is the water pump! any ideas would be much appretiated!
thanks
pettal,
Oct 20, 5:10am
radiator could be blocked , also check the preasure capand that the hoses are in good order .
NZTools,
Oct 20, 5:11am
Did you have the headplaned and crack tested while it was off!
m16d,
Oct 20, 7:04am
Dog of a motor.always cracking heads. Just bif the motor out and put something decent in it.
flack88,
Oct 20, 8:51am
Or an airlock,have you been driving it since the gasket done!did you prime the block when the thermostat out/!What sort of 'glue' are using!
budgel,
Oct 20, 8:58am
How quick is it pressurising!If almost immediately it will be from combustion.
Get a test done for combustion gases in the cooling system and go from there.If no gases, then radiator or waterpump.
Take your thermostat out, top up waterand run the engine with the radiator cap off,if water flowing, the water pump will be working. It should be noticeably faster when the engine is revved.
Oct 20, 9:19am
You never ever refit those old Mazda heads without getting them crack and hardness tested and checked for warpage, they are prone to all three of those problems. Its usually the result of years of chugging around with blocked radiator tubes that weren't professionally cleaned out on time.
