Toyota ipsum 1997 water pump
gag5, Oct 22, 8:20pm
Does anyone know whether the water pump in the toyota ipsum 1997 is run by the cambelt and would need to be replaced if the water pump is broken
gadgit3, Oct 23, 5:33am
Yes water pump is cambelt driven. Engine is a 3S-FE
intrade, Oct 23, 5:46am
engine is non interfearance but headgasket blow out if it overheats , head wont crack unless seveare overheated.also do valve clearane as these has shim and buckets
kazbanz, Oct 23, 8:15am
Gag I think you probably misunderstand the point thats being made.
NO you do not NEED to replace the cambelt when replacing a damaged/worn out water pump. But unless the belt is all but brand new you would be mad not to replace it.
The reason being that the mechanic is going to remove/replace the belt anyway regardless of if its a new one or the old one. This means you get a new beltfitted and only pay the price of the actual belt itself. saving yourself hundreds
gadgit3, Oct 23, 10:31am
Nah I understood the point. If this came into our shop with a broken water pump we would be replacing the cambelt reguardless, as the belts don't much like containimation like coolant and they also don't like running on there side or loose if the water pump is "broken"
kazbanz, Oct 23, 11:24am
do wot! not you gadget--gag/OP was who I was replying to.
gag5, Oct 23, 7:07pm
thanks for that info - any idea how much a cam belt would cost! The mechanic has only quoted the cost of the waterpump & 5hrs labour. Wonder why he didnt suggest a new cambelt!
gadgit3, Oct 23, 7:22pm
Oh sweet as kaz sorry bout that.
Gag a new genuine belt is $55+gst
llortmt, Oct 23, 7:29pm
I'd refuse to do the job without a new belt.
If you want a bodge job find a back yard mechanic.
gag5, Oct 23, 7:43pm
hey thanks for that - will get the new belt fitted then - silly not to!
Have a great night. Cheers.
incar., Oct 23, 10:20pm
change the belt, if the water pump is faulty to the extent that it has play which increased slack in the belt then it would be slapping/contacting covers, housings etc, and could cause damage to the belt, but not many mechanics would re-use the belt, for $30-40 replace it
gag5, Oct 25, 7:01pm
well, it turned out it wasnt the waterpump. It was a welsh plug behind the water pump that was leaking. So a new cam belt & tensioner was fitted.
Thanks for all the helpful posts.
