How do you set timing mazda e2000
chuckyme, Oct 27, 4:11pm
just want to know where the a.b.cxon the rocker cam gear go cant see tdc engine to dirty how do you set it up!
budgel, Oct 27, 8:02pm
Start by cleaning the engine.
a.woodrow, Oct 27, 8:05pm
^^this
chuckyme, Oct 27, 8:22pm
nah not my car just fixing for someone lol
a.woodrow, Oct 27, 10:53pm
You won't be fixing it if you can't see the marks
snoopy221, Oct 28, 2:01am
Just DEAL with it like any simple engine with a camshaft and a crankshaft and TIME THEM ACCORDINGLY.
Or PAY SOMEONE WHO CAN.
landyandy, Oct 28, 6:12am
set the valves on the rock,number 4 just closing and other just opening then the one b on the compression stroke,then h ave a look u shld c something that resembles marks on yr dirty crank pully and front of cam sprocket
NZTools, Oct 28, 6:31am
If it is that dirty that you cant see the timing marks, the last thing you should be doing is putting it back together. It obviously has issues with oil leaks in the cambelt area already.
mugenb20b, Oct 28, 6:39am
x1
It takes.like 10 seconds to clean the crank pulley and lower timing cover.
Then you can SEE and line up TDC on the crank pulley.
Once you've found TDC.you'll see where the cam timing mark is.
chuckyme, Oct 28, 1:47pm
thanks all got it sorted
