if its not a heavy duty clutch,my guess would be someonemightnot have lined up the friction disc 100%and forced the box on
carmedic,
Nov 10, 4:23pm
Is the judder exactly the same as it was prior to fitting the new clutch! Was is a full 3 part clutch kit!
panicky,
Nov 10, 4:25pm
does it shudder on release! or going around corners!I have seen a bellhousing on one of these crack and cause a shudder, was only obvious when loaded up on release.
anythingfast,
Nov 10, 4:30pm
thanks panicky, looking into it
Feb 15, 4:50am
Loose and/or stuffed engine mounts are also a potential cause of clutch judder.
