WRX ENGINE MOUNTS
tumekegolfer, Nov 21, 4:40pm
HELLO CAN SOME ONE TELL ME ARE THE ENGINE MOUNTS EASY TO CHANGE ON A 96 WRX IF NOT HOW MUCH WILL IT COST I,M JUST ASKING BECAUSE I,M NOT TO SURE ABOUT SWAPPING MY CAR FOR A WRX THAT NEEDS THE MOUNTS CHANGED THANKS
ninja_man, Nov 21, 4:41pm
TAKE YOUR CAPS LOCK OFF
tumekegolfer, Nov 21, 4:41pm
WOULD THIS BE WHY THE CAR SHUDDERS BEFORE TAKE OFF AND SOMETIMES WHILE DRIVING CHEERS
hijacka, Nov 21, 4:51pm
HI! I DON'T KNOW IF YOU CAN HEARRR ME DOWN THERE BUT THE ANSWER TO YOUR QUESTION IS YES THEY ARE EASY TO CHANGE AND BEST TO REPLACE THEM WITH THE SQUARE ONES INSTEAD OF THE ROUND ONES! ALSO CHECK THE GEARBOX MOUNT AND YES THEY MAY CAUSE SHUDDERING BUT SO CAN A F$#KED CLUTCH SO DEPENDS REALLY ON WHAT YOU EXACTLY MEAN BY ''SHUDDERING''-
tumekegolfer, Apr 3, 9:43pm
thanks hijacka for your advice cheers mate
