knock.is there a liquid additive i can put in it to quieten it .only obvious on start up for 60 -90 seconds.
ginga4lyfe,
Nov 10, 5:34pm
Probably more oil if the oil level is low.
ginga4lyfe,
Nov 10, 5:34pm
does it go away if the stereo is turned up! that may be a good quick fix!
a.woodrow,
Nov 10, 5:37pm
Is it overdue for a service!
Nov 10, 5:37pm
If its knocking its trying to tell you theres something wrong. I would take that warning as a chance to fix the problem before it becomes expensive to fix
appleman71,
Feb 16, 2:15am
ok,turning the stereo up sounds the cheapest short term solution!
