Hi, My car battery keeps randomly going flat, ive noticed that when I turn the heater/lights/indicator/radio on the battery level drops dramatically does anyone know what could be causing this! the battery itself is only about 9 months old.
mrfxit,
Nov 8, 6:19am
Simplist solution is to take it to a sparky & get a voltage drain/ chargetest done. Talk nicely to them & they may do it for free. it's only about a 10 minute job (all up)
saxman99,
Nov 8, 6:20am
Could be a fault with the alternator.
n1smo_gtir,
Nov 8, 7:25am
Do you have a sound system installed with an amp! Sometimes if the knob didn't install remote wire properly. The amp could drain ur battery flat. Seen it a few times fixing people's installs.
bellky,
Nov 8, 7:27am
If your battery checks out then obviously you have a wiring problem.
