Nissan Expert Speedo Error Q.
neville48, Dec 19, 7:23pm
I have a 2004 nissan expert and at 100km the speedo reads 110km. It has the correct size tyres, is this an electronic problem and ideas for a fix please.
splinter67, Dec 20, 5:48am
Most cars read fast
kazbanz, Dec 20, 7:19am
neville. looking at the most simple solution.How certain are you that the vehicle is definitely fitted with the correct size tyres!
Factory tyres are pretty small. Something like 165/70/14 from memory.
Not being a smart alec here but its one possibility
kevymtnz, Dec 20, 7:54am
yr lucky i thought my old car was bang on n thought why is this cop want me at 103-104kph on speedo ticket for 109kph cheers govtso mines 5km slow
wizid, Dec 20, 8:04am
my 02 skylinewhen reading50ks its doing 30ks .when reading 100ks its only doing 90ks
mm12345, Dec 20, 9:40am
With standard tyres, 100km/h at verified (ie GPS) 100km/h seems a little high perhaps, but not unusual.At 100km/h our three vehicles read 100km/h (old Safari) , 106km/h and 108km/h.
If you check your odometer, you'll probably find that's close to spot-on.
tigra, Dec 20, 9:53am
My hack Avenir "gopher" wagon is about 5kmph too high at 100km
wizid, Dec 20, 11:35am
i put mine on the dino .as too many hondasand small toy motors were passing me . thats how i found out
kazbanz, Dec 20, 11:40am
SorryNeville I hadn't had my morning coffee. I was talking the nissan AD not the avenir expert.
The expert "factory" tyre is a 165 r15 which is quite a high profile tyre kinda like an 80 series. Its most likely you have 175/65/15 on the car
neville48, Dec 20, 1:14pm
The car has 175/65/14 as per the sticker in the rear door jamb so that must be factory ! To the other posters telling me they are that far out with their speedo's, mine is 10% out, thats not good enough and that just adds to the total mileage as well, there must be an adjustment to the electronics somewhere, hence the post.Any more help or advice, cheers Nev.
wizid, Dec 20, 1:39pm
i asked the nissan poeple thay said thay could not adjust it . my bluebird was about 15ks out at 100. was told by a wreacker to take out the speed sender . clean it and put it back in . this did work for awhile . but went out by 20ks at 100. so i brought a sat nav . now i have 2 nagging woman telling me iam going to fast hahah
4piggy, Dec 20, 8:13pm
robinson instruments can supply a adjustable unit to alter signals and correct speedo or they are listed for motor bikes for when changing to different sprockets
pickles26, Dec 20, 8:25pm
Nissan speedos and rev counters are adjustable it will need to be dismantled and a hole drilled in case for adjustment access however I am not sure if you would get 10 kmh adjustment out of it. They also suffer from leaky capacitors which can affect speed reading. Speeds should be close to exact not high as mentioned in here a lot.
sky_biker, May 15, 4:03pm
Better to get there late than DEAD on time
