Air in cooling system
leanne_6, Jan 24, 3:20pm
my car has air in the cooling system, i have noticed that the coolant header tank has a hairline crack, when the system is under pressure it leaks out the crack, should i be looking for any other cause or just replace header tank and cap!
leanne_6, Jan 24, 3:27pm
car is a holden vectra 2.0 2000 manual
jmma, Jan 24, 3:27pm
Is the car overheating at all, better to replace radiator.
What is the make model etc!
pfemstn, Jan 24, 3:36pm
vectraknownfor headgasket problems would pay to get it checked out properly
leanne_6, Jan 24, 3:36pm
seems slightly hotter than usual but not overheating, car is holden vectra 2000, tank would be about 13 years old, and is discoloured around the crack, tank has the crusty white from where the coolant has been leaking
sniff test!
lugee, Jan 24, 3:50pm
Its probable that air is being sucked in through the crack when the engine cools and pressure drops. May as well get the tank replaced and go from there, need to anyway.
leanne_6, Jan 24, 4:00pm
how much is a test for gasses in the coolant usually!
leanne_6, Jan 24, 4:08pm
ok just rang a garage will get it tested, thanks
mugenb20b, Jan 24, 4:53pm
SFA. 5 minutes labour.
