No power to solinoid on starter
briantamaki-god, Mar 13, 5:19pm
but power at back of ignition switch when turned
is there a fuse for this? if so where would it be on a e25 Nissan caravan?
msigg, Mar 13, 7:18pm
yes there will be and a relay, probably. What I do is get a good torch and try trace the wire/ right colour back from the starter, or from the ignition forward, try downloading a wiring diagram from the internet. side panels or under seats., behind front seats, it's a guess.
briantamaki-god, May 1, 7:48am
thanks for your help :) turns out it was the switch on the clutch pedal
