had my Triton in getting a service at the dealership yesterday in whangerei.
on the was home I noticed that it seems gutless when I got to the first passing lane just south of whangerei. Had it in 4th and it was slowing down which is unusual as it normally fly's up there!
after about 45 min it seemed to be a but better but it went back to being gutless again this arvo when I went for a 20 min driver to work but on the way back it was fine again.
Have checked vacuum lines to the turbo and they all seem to be fine but just does not feel like the turbo is working properly.
Thoughts? will give the dealership a call tomorrow
henderson_guy,
Dec 9, 7:28pm
Wastegate sticking open? Struck that recently.
Dec 9, 7:31pm
maybe they can wind your chain back up 3 days.
brapbrap8,
Dec 9, 7:32pm
My guess is the EGR and intake manifold are full of carbon which is extremely common in mitsis. I would have thought it would have a check engine light on though.
wind.turbine,
Dec 9, 7:36pm
Na won't be the manifold as that's just been cleaned the egr valve replaced, my thoughts as well with stuck waste gate
snoopy221,
Dec 9, 7:36pm
ROFLMAO PMSL.
wind.turbine,
Dec 9, 7:37pm
haha my air con is working fine thanks!
rctr,
Dec 9, 8:21pm
Hole in map sensor pipe. Not sensing correct boost so is not fueling. Check vacuum hose from intake manifold to
bigfatmat1,
Dec 10, 5:50am
Suction control valves are a common failure.
bjmh,
Dec 10, 6:27am
air trapped in the new fuel filter they replaced at service ?
wind.turbine,
Dec 10, 7:49am
did not get a new one as it was I replaced it between services
jgiblin,
Dec 14, 7:53pm
check suction control valve.
very bad engine for blocking boost sensors and inlet manifolds.
wind.turbine,
Jun 18, 11:04am
will go back to the dealer next week all going well. seemed to have sorted its self but now have had check engine light come on after getting rear ended on the beach while pulling some dumb a$$ out as they got there van stuck, was told to stop then next min smack! so into the panel beaters for new tail gate and bumper and the suspension has also all shifted forwards.
not too sure if they caused the engine light but it caused me a headake with trying to get back off the beach meyself as it went into limp mode but the light has since gone off again
