crazy question I know but does anyone here know the colour of Z's Diesel fuel? the young fulla took his petrol ute in early this morning and chucked $20 in his tank, went to pay for it and they told him it was diesel, now although I wouldnt put it past him he parked the ute up at the servo and we towed it home whilst hes at work, I drained the tank from the drain plug and would have only got just over 20 litres out (the guage is shot so Id say hes bloody lucky there if nothing else), thing is with the price of diesel at the moment I would say 95% should be diesel if thats the case, but it sure doesnt smell like it, smells exactly as it should IMHO and its red in colour, I know 95 octane has a yellow tinge to it and thought 91 was red? not sure what he normally runs in it by the way but Im assuming 91.
daryl14,
Jan 13, 1:14pm
Diesel oily between the fingers. Petrol not.
Jan 13, 1:15pm
rub a bit between your fingers if any form of lubrication can be detected then its diesel. having said that i had diesel that was almost like petrol with almost no lube when i done tests with ulsd diesel. you cant go by colour fuel is clear and the colour is what they add to the fuel
mrfxit,
Jan 13, 1:17pm
Plus petrol will PULL the oil out of your fingers after it drys
If thats 95% diesel you have there, then a small sample pot tested for ignition will light & burn slow when compared to straight petrol, Be safe, not silly
Jan 13, 1:19pm
especially at 30 degrees outside petrol is highly explosive
youngones2,
Jan 13, 1:44pm
Filled up at z this arvo and it is a greenish colour.
brapbrap8,
Jan 13, 1:47pm
Another reason to use the pay at the pump at Z, it asks you to select what type of fuel you need before you fill up.
supernova2,
Jan 13, 3:26pm
Dont know if this would work but shake it up in a bottle. Diesel foams but must admit have never bothered to consider what petrol might do. Also petrol evaporates quickly diesel says around for ever as its an oil. Red sounds like petrol to me.
jmma,
Jan 13, 3:34pm
Must have different ones at all our Z's in the lower north Island, Ours don't ask that.
budgel,
Jan 14, 7:51am
Diesel has almost no taste, petrol burns your mouth.
Dont ask how I know this.
exwesty,
Jan 14, 9:34am
The fuel receipt will tell the story. Or ring them and ask them to check the transaction for the pump at that time.
mrfxit,
Jan 14, 11:23am
Hate both that way (also, don't ask)
motorboy2011,
Jan 14, 3:14pm
Petrol will light on fire.
smac,
Jan 14, 3:19pm
Only if they got the right pump. If it's petrol I'd say the whole issue is they thought he was on a different pump than he was charged for.
next-to-normal,
Jan 27, 4:18am
probably told the other guy he got petrol in his diesel
