VT Calais heater/air con fan removal/replacement
catwoman1974, Jan 11, 2:16pm
Approx. how long would it take to remove fan and fit a new one? TIA
neell, Jan 11, 4:45pm
Have to ask, what makes you think it needs replacing?
catwoman1974, Jan 11, 5:09pm
Erm, it's not working properly, blows very little on high.
neell, Jan 11, 5:15pm
I suggest you check/get checked the resister they are more prone to fail than the fan itself.
catwoman1974, Jan 11, 5:23pm
Yes, I'm aware of that. When faulty, the fan only works on high which is different to the problem I'm experiencing at the moment.
a.woodrow, Jan 11, 5:26pm
When the fan is faulty however it usually doesn't go at all. Calais fan control IIRC is also affected by BCM, but resistor should be first point of call
catwoman1974, Feb 2, 1:26pm
Update:
Fan was faulty not resistor
