Mitsi Cedia 4g93 gdi wont start
shane038, Apr 13, 11:12am
Have just inherited this car to repair, it lost the Alternator belt at some stage, however when I crank it it sounds like it has no compression, don't think the Cambelt has slipped but it winds over and sounds like there are no spark plugs in it
Any help would be appreciated
lugee, Apr 13, 11:17am
Have a look at something that should be spinning in/on the head while it's cranking. Not familiar with that particular engine, but distributors, cam sensors and seeing if you can see anything through the oil filler should work.
evo_spares, Apr 13, 11:21am
to start off use a 2 channel Oscilliscope and reference cam over crank or and ignition over injection
thunderbolt, Apr 13, 11:34am
Did the alt belt also drive the water pump?
Any water in the radiator?
Wondering if it has been cooked.
lugee, Apr 13, 1:44pm
Cam belt driven.
It takes more than just a slipped belt to make it sound like it has no plugs (when it has plugs), more like a broken/stripped belt outright. First thing I'd do is check cam is actually rotating.
shane038, Mar 16, 12:08pm
Cam is rotating thru oil filler hole
