Hi can anyone help with a box of unused piston heads. The tops are stamped RA2508 STD , TOP 00 17 RJ and they are also marked 2508 STD inside. Finally a green tag on the box says 6KRY 2508 STD Engine Kit 3.680. I have tried all over the net and no results except that they might be older Ford 6 cylinder set ? . cheers
OK , so these are for early six cylinder Ford Mustangs ? . awesome and thanks for the fast reply . cheers
rob_man,
Oct 17, 3:37pm
The bore size is the same and the google results for that size only threw up the ford engine. I googled 3.680 bore size from the description in your post. The Falcon 200 ci motor will be the same.
Deep dish 250ci falcon. 22cc bowl. But in std size relatively useless unless some is sleeving one back. Unlikely to find one with a good bore these days.
pottynz,
Oct 17, 4:22pm
Thank's for that info . a bit out of my area of expertise . cheers
pottynz,
Feb 1, 11:15am
Thanks Wayne . appreciate the link . cheers
