Toyota vitz where is the
toyboy3, Jun 8, 3:36pm
Jack kept , it isn't near the spare wheel?
curlcrown, Jun 8, 3:39pm
possibly under the passenger's seat.
andrewph, Jun 8, 3:59pm
From memory behind the spare wheel held into a small bracket with a rubber strap. If its not there check the pockets behind the rear wheel arches inside the boot. The jack handle is usually clipped to the bottom of the spare wheel cover.
peja, Jun 8, 4:04pm
Unusually enough its under and behind either the passenger or driver seat, cant recall which. Can check partner's Vitz when I get home from work if you like
noswalg, Jun 8, 4:08pm
yep check under the seat, took me a couple of hours to find the one in the missus's Vitz when she bought it.
nesta129, Jun 8, 7:03pm
Yup under the front passenger seat,only accessible from the back seat.It has a back facing cover on it that has two tabs.Pull together to release the cover and there you have the jack.
kazbanz, Jun 9, 9:04am
it depends which model vitz? 00-05 (old shape) -in boot "behind" the spare wheel;-ie closer to the back bumper
or 05 and newer -under LF seat -back edge --plastic cover over it and there it is
rob_man, Jul 11, 4:08am
They don't need a jack, you should be able to just lift the offending wheel off the ground and get your missus to swap the wheel.
