Query. Can the car ECU (on-board computer) be interrogated to check if the digital odometer has had a 'wind-back'?. Thanks.
Sep 27, 7:20am
in what car?
bumfacingdown,
Sep 27, 7:53am
Red one
clark20,
Sep 27, 9:04am
One with an ECU ! That that must cut it down to 75% of cars?
drog,
Sep 27, 9:10am
For Kaz: 'Skyactiv' Mazda 3. Excuse my ignorance everyone - I'm an old reprobate.
johotech,
Sep 27, 9:13am
Perfect fit for this forum.
drog,
Sep 27, 9:16am
Ta.
clark20,
Sep 27, 9:27am
Mazda is probably the best place to take it to and ask.
Sep 27, 10:17am
yes the thing is the answer it spits out might or might not be the truth. Like on my vw i got the function to check odometer tempering via factory scan tool. on my one it just comes up as function not implicated because it only stores the odometer data on the instrument chip. To figure if tempering has occured 2 or more places must be called uppon for milage or prediced milage records. if they dont mach witin each others parameters 20% maximum for a example over 200 tousend km. then the system will show as tempered . most cars have 3 or more places where odometer records are stored. Would you reprogramm them all to the same readings, then no tempering would be detected . Ignition lock number 1 instrument cluster numer 2 engine controller 3 and gearbox 4 all can have odometer milage recording chip, deviation between these are detected as tempering.
petal_91,
May 1, 4:16am
If it is NZ new then surely the odometer will be correct. In NZ no one clocks petrol cars, only diesels.
