Speedo stuck.
muzz67, Aug 10, 3:09am
70's japanese cable drive speedo stuck at 70kph.
Noticed last time out speedo was a bit slow to react to speed changes, now needle stopped.
Mileage still goin up, assume not a cable problem.
Any suggestions as to where to send it to appreciated,
Muzz.
mrfxit, Aug 10, 3:17am
Pull the cluster out, crc the speedo needle bearing & a touch of machine oil afterwards
snoopy221, Aug 10, 3:36am
Damn thang is tryn ta be a nissan terrano famous for zee ole plastic needle bending and hanging it upski
But because it ain't lube er up as above
jmma, Aug 10, 3:45am
May have oil coming up the cable, but you will soon see that.
poppy62, Aug 10, 5:16am
Inner Cable is broken and snagged at 70kph.
skull, Aug 10, 7:23am
We are so lucky to have an intelligent person with us this evening.
mrfxit, Aug 10, 6:52pm
Normally a .
Slow down in needle response will be a dry bearing
Erratic needle can be oil in the cable or a fraying cable
Jumping needle (large jumps) will often be a broken cable & the end bits snatching at each other, OR a missing tooth on the drive gear (either end)
A needle that simply sticks in place at a set point & can be (often) made to return by giving the gauge cluster a good thump, will be a buckled cluster face or peeling paint catching the needle or bent plastic needle, (or it's already been apart & the twit bent the needle).
Not always but more often then not.
muzz67, Aug 10, 7:06pm
Thanks guys,, will have to figure out how to remove it now.
supernova2, Oct 31, 2:03am
These guys usually cheaper
http://www.eparrott.co.nz/ than these https://www.robinsoninstruments.co.nz/
Another option is fine a good clock/watch repairer.
