Mobil at Panmure only sells diesel and 91
bantam3, Sep 14, 4:02am
Had to call into the Mobil petrol station at the Panmure roundabout as was running low. I always use 95 or 98 in my vehicles as thats what it says to use in the handbook and every mechanic will tell you the same.
Drove to every pump but couldn't 95. Went into the shop and was told they no longer sell it.
I wonder what the car manufacturers would say?
intrade, Sep 14, 4:05am
go somwhere else only fill 10 bux 91 and get some bp 98 that will bounce it back up enough. dont ever use any other 98 then bp the others are laced with ethanol as far as i know and thats worse then 91
poppy62, Sep 14, 4:38am
Are you scaremongering again Intrade? Show where Mobil 98 is laced with Ethanol!
intrade, Sep 14, 4:48am
i am talking about the G company and i never seen no 98 at any mobile i seen bp switched mostly 98 now tekuiti taumarunui both 98 now and the mobile has the 95
bantam3, Sep 25, 4:13am
Obviously the petrol station doesn't sell enough 95 or 98 to warrant having it in stock. Is the 91 harming new vehicles. I doubt car manufacturers will cover any damage to the motor if you use the wrong octane rated fuel.
