Daihatsu Coo/Materia same stereo wiring as Toyota?
ambo11,
Dec 7, 8:33pm
Got a 2006 Daihatsu Coo for a runabout, apparently these are basically the same as a Toyota BB? My question is will the stereo wiring be the same, as in can I buy a used plug and play Toyota double din stereo and it will plug straight into the Coo wiring system? Thank You
Dec 7, 8:46pm
well most easy is to find out by removal and inspection of the wiring and plugs.
Dec 7, 9:14pm
Ambo-short version YES The wiring is the same for both
ambo11,
Dec 7, 9:32pm
Kaz, thank you. So if I want another plastic door lock opener (forget the name) as this has no actual key, would a Toyota BB OR Daihatsu fob thing be both the same, as in both programmable? Have a small alloy tag with a number on it for the one I have. Thanks for the help
