Aftermarket Cruise Control 2007 Honda Civic Hybrid
proracer, Mar 14, 9:16pm
Any ideas how much $$$ to fit after market Cruise control to a 2007 Honda Accord Hydrid?
Any info be welcome.
Based in Waikato/B.O.P area if anyone keen on supply and fit.
proracer, Mar 14, 10:51pm
No Auto Sparkies here?
intrade, Mar 14, 11:39pm
hibrid could be quite difficult .as it drives from electric and combustion. electric means throttle position is different.
aftermarket usually command the throttle . unless a specific kit exists who can be coded in to the system i would say not possible unless you spend a few hundred million doller to develop a integratable kit.
kazbanz, Mar 15, 12:09am
First of all you need to establish if cruise was a factory option. if so then a factory kit is the way to go.
tamarillo, Mar 15, 3:09am
s_nz, Mar 15, 8:45am
Above link says "From $999 including GST". Not going to be economically viable on a 2007 civic. Cheaper for OP to sell their current car and buy a different car with the features they want.
Given the civic was offered with cruise control, the real question is if the factory cruise bits can be cheaply sourced (wrecker etc), and if they will plug and play.
bryshaw, Mar 15, 9:05am
Both my Jazz manual and Civic auto have cruise control. They are integrated into the steering wheel controls so adding later would appear expensive. The Civic cruise control is very accurate and smooth, so handy on long journeys where speed cameras in vans are everywhere.
franc123, Mar 15, 9:12am
As soon as you are dealing with electronic throttle control it all becomes a lot more complicated, cruise cannot be added in as it's a function of the engine or powertrain control module that responds directly to commands from the steering wheel controls and from vehicle speed information gathered via CANBUS from the ABS unit, it has to have provision for it, it cannot be done with an external controller acting directly on the throttle linkage. It's not often that cruise is specified on JDM stuff.
tygertung, Sep 3, 4:43pm
What if you had a servo motor which acted on the throttle pedal, and a microswitch to cut off the cruise control which was on the brake pedal?
