Help with Hyundai Getz Radio
ract, Mar 26, 5:27am
Hi there, I am in need of some help with my Hyundai Getz radio.
The car’s battery had been disconnected and when reconnected the security code was needed to be set back into the radio.This is where it all goes wrong for me, as I do have the code but the buttons on the radio will not accept them, nothing shows on the radio as the buttons are pressed. Before the battery was disconnected the radio worked fine but could not be switched off if the ignition was on. I have tried disconnecting the battery overnight to see if the radio would reset (like powering down a computer to reset)
I know that the security code that I have is correct.It came with the car when we purchased it new and has been used before.
gazzat22, Mar 26, 10:08pm
Go to the nearest Hyundai agent.
kazbanz, Aug 30, 2:41am
Gummed up buttons?
