Repairing a small hole between Cylinder sleeve & b
spudster, Jun 8, 10:49pm
Is there any way to repair a small hole between the cylinder sleeve and block? It is at the top where the head gasket sits and allowing a small amount of coolant into the cylinder.
Engine is a DS11.
Thanks
redhead18, Jun 9, 12:14am
LOL Yes strip down remove all liners and replace top liner sealing rings and bottom o rings where fitted and re assemble
ofaatudesigns, Jun 9, 12:21am
What if you do something dodgy like drilling and tapping a thread, then putting a bolt into it, then cut it off flush?
gph1961, Jun 9, 12:34am
self tapper
tony9, Jun 9, 2:56am
car__parts, Jun 9, 3:04am
If the hole is between the sleeve and the block it should not leak water into the cylinder and the head gasket should seal. If there was water getting through to the cylinder there would also be air going back to the water gallerys causing the system to pressurise.
cabrio1, Jun 9, 6:31am
Skim the top of the block.
bwg11, Jun 10, 11:46pm
Just curious, Scania or Citroen DS11?
redhead18, Jun 11, 7:10am
A Wet liner DS11 Andre Citroen with a leaking liner?
[Methink scania marine=hence liner leaking ring]
elect70, Jun 11, 9:41am
Try chemiweld Ihad cracked head on landrover leaking water into chamber
. Bottle of chemiweld fixed it
bwg11, Jul 28, 3:52am
Thanks redhead18, I was just curious, having a bit of a snoop. Now I'm sure.
