Will 1997 Isuzu bighorn 3.1 alternator fit a 1994?
tup,
Aug 16, 8:32pm
before i put it all back together again. will a 97 alternator (same engine) work on a 1994? plug location is abit different but otherwise looks the same. thanks :)
Aug 16, 8:39pm
The only problem i have found is the vac pump on diesel to be to long . on a isuzu elf 4wd there was a hose going down the back stopping it to be adjusted because the vac pump was a bit longer on aftermarket one. Diesel have a vacuum pump on back of alternator normally on isuzu if the alternator dimensions are all the same it should fit.
msigg,
Aug 16, 8:49pm
Well this will work but you may need to alter the mounting brackets and different size belt, if you are handy with tools and such all good, does take a bit of time and can be fiddly. Yes electrical connections could be different but can be changed, all depends on you. If you like stuffing around.
tup,
Dec 6, 1:41pm
thanks heaps guys. really appreciate it. looks like the 94 is a 50amp where the 97 is 80amp which is a massive difference too. no wonder it wasn't charging my massive battery. lol
