the display screen has frozen so i cannot change radio stations or change aircon settings.Anyone come across this?The screen lights up but the touch screen dos not work.Any advice woud be appreciated.thanks in advance cheers
s_nz,
Sep 14, 6:20am
Restart it somehow.
Taking the negitive off the car battery for some minutes may be the essayist way. But you could also take the unit out and put it back in, or see if holding down power restarts it etc.
sue72,
Sep 14, 6:38am
i thought about dis connecting it but thought the radio will be wanting a code to restart
bigfatmat1,
Sep 14, 7:59am
Disconnect batt for a few mins
sue72,
Sep 21, 6:17am
disconnected a few times but still no change apart from now the radio stations have gone and no way to retune
Sep 21, 7:11am
most probably electronics failed . what you need is the factory scantool hooked up check for codes and if there is a TSb to flash the electronics pooh to fix a known problem. otherwise repmoval and repair or replace once wiring and other modules are checked and the fault is within the unit.
sue72,
Sep 21, 7:28am
do i need to take to a toyota dealer or any auto electrician?thanks
How long are you leaving it all disconnected for? Also do you have the factory disk or SD card for the car?
sue72,
Nov 17, 4:12am
disconnected for a few mins,no dish or card.thanks
