I would like to get a towbar fitted to our Majesta but has been mentioned that I cannot because it will cause trouble with the sensors at the rear of the vehicle. is this a fact ? Kaz ?
Aug 4, 3:15am
You have reversing sensors I assume. That doesn't stop you getting a towbar fitted but unless you have a silencer button can be a real pain as the trailer can make the sensors go off --even the towbar itself if they are positioned wrong. I'd suggest go see an auto sparky and see if the sensors can be silenced for towing.
msigg,
Aug 4, 3:21am
No it shouldn't set the sensors off , I would have thought it would be lower than the sensors. Mybe only reversing they will set off.
andy61,
Aug 4, 3:25am
Lovely cars but OMG cracked dashboards? Puts me right off!
bigfatmat1,
Aug 4, 3:32am
Fit towbars to cars with sensors all the time never a problem.
nzmax,
Aug 4, 4:31am
Have a Nissan branded towbar fitted to my Maxima with factory reverse sensors, no issue at all. Backing out the drive way sets them off more than reversing the trailer in a straight line, unless you have the trailer on an angle, then it thinks you are too close.
toenail,
Aug 5, 5:46am
your trailer should be far away enough that it doesn't set off the reversing sensors. If it does, your sensors are misaligned.
neville48,
Aug 11, 1:59am
Yur not wrong Andy but look past the cracked dash and you get a hellova lot of car for the price.
panicky,
Aug 11, 3:20am
normally with reverse sensors you'd be able to get a tow plug connector fitted to the vehicle that has a reed switch in the hinge so that when the connector is plugged in it literally disconnects the sensors. You can get 7 pin plugs with reed switches that are open or closed normally to suit different wiring.
