I have a Mitsubishi Airtrek Turbo which had timing belt replaced 70k ago. Everything was replaced .Both belts tensioners .water pump. It has now developed a noise which is worsening from that area. I have released the tension on the drive belt and the noise stopped. So can rule out air con ,power steering pump and alternator. Looks like I will have to replace everything again. Any help?
sirdoug,
Feb 21, 10:08pm
sorry ,should have read the noise didnt stop when drive belt released.
gazzat22,
Feb 21, 10:38pm
As a start take the cover off and make sure nothing is loose or has worked loose. cheers
Feb 22, 12:35am
get it done soonest i ignored a noise on my astra s its belt was done 25k ago by me, the waterpump bearing was seeazing up making the noise. it was a new oem pump also= why i ignored it till the belt broke and valves bent. found out after the fact .
Feb 22, 12:38am
so hang on removal of drive belts outside cover did stop your noise/? ok i see your post after its inside timing cover. yes replace it all again is the only way try get bosch or gates parts or denso.
sirdoug,
Feb 22, 12:40am
Thanks.Thats exactly what I am thinking
sirdoug,
Feb 22, 12:42am
No .I made an error explaining it the original post.Releasing the drive belt did not stop the noise.
Feb 22, 12:47am
its one big nightmare now. i fitted SKF wheel bearing to my car. but somone f. d the hub up so the play was in the hub not the bearing . so i pulled the hub this split the sealed bearing open and i found almost no grease in the bearing. so i refilled it with more grease the new SKF bearing before i fitted the new hub. i also seen starter motors for cheap failed after 3 month. the bearing never had any grease in them at all. waterpump bearings you are screwd if they have no or insufficient grease
sirdoug,
Feb 22, 12:54am
I think it can only be an idler or water pump bearing .Could the water pump or idler fail and derail the belt.Thanks for your help.
Feb 22, 1:01am
How many years ago was the work done? If something like this happens in the last 30% of a timing belts scheduled life then it might just be a case of just biting the bullet and redoing it. You could try removing the upper belt cover, starting the engine and giving the belt a tiny squirt of water to see if the noise changes. While it's running observe the belt for any defects in its surface.
sirdoug,
Feb 22, 1:07am
Work was done 7 years ago and at 70k km. I will try what you say.
Sep 11, 9:50pm
Put simply--don't muck around. The vehicle has done 70 k since being done--so 140 k in total--BUT its been 7 years. That's long enough for a seal to leak or a belt to break down. --Right now its an inconvenience.--wait and it COULD be Chernoble. -equally could be something simple
