Battery relocate
pbsrb5, Jan 8, 2:10am
Hi all,
Im currently having a 1980 Ford restored.
It is a South African import and has never been registered here.
The plan is to restore to OE specs as much as possible, but one thing I would like to be able to do is relocate the battery from the engine bay to the boot.
It has had a lot of rust repaired and this has been checked by a certifier but i am keen to find out if the battery relocate is allowable or will it mean I will have to go through Low volume certification?
If anyone has experience of this I would be keen to here.
Thanks
curlcrown, Jan 8, 2:25am
Might be a lot less painfull to leave it where it is to comply it then move it later.
kazbanz, Jan 8, 2:31am
Don't do anything at all until its complied. It really REALLY isn't worth the drama.
PS--this isn't a generic reply but a reply to your specific issue.
alowishes, Jan 8, 2:34am
Once you have got it complied move the battery to the boot if you want.
Mount it good and solid and put it in a vented marine box.
And run the fattest leads you can get, particularly for the positive (+) lead to compensate for the distance from the battery to starter.
sw20, Jan 8, 2:54am
2/0 OFC welding cable.
socram, Jan 8, 7:29am
I used a battery cable from an old Mini. They always had the battery in the boot. But agree with above, get the compliance done first.
rectech, Jan 8, 6:22pm
Suggest marine grade anchor winch cable, multi strand supper flexible. batteries in boats are located in the back of boat so it a common and easy solved problem
sandypheet, Jan 8, 9:33pm
Not very far from the engine.
bumfacingdown, Oct 1, 4:08am
But a long way from the anchor winch
