(2.7td automatic) Right, ill try explain this best i can. when you start the truck in the morning it will start fine, idle fine. but when you drive it wont change out of 1st gear, when you button off the throttle it will then change gear (say 2nd or 3rd) but when you pull up to stop the truck appears to stay in these gears and stall. then when you re-start itwill proceed to do the same thing. now . it will only do this for maybe 5 minutes or sothen it runs like a dream for the rest of the day with no issues at all. we've checked pipes around turbo and throttle body, replaced diesel injector pump(2nd hand) ,new fuel filter, injector cleaner, and replaced a sensor at front of engine cover(forgot what it was). we're thinking if it was afm we would have continuous problems not just issues in the morning. any suggestions would be most appreciated. Thanks.
Oct 10, 11:24pm
Is this the later curvy shape (PR50 chassis), or the one that was designed with a 6" ruler!
melanieg1,
Dec 25, 1:07pm
Haha pr50.
