MSD Ignition experts.
paddyman, Jan 21, 3:33pm
Got one in a HQ, just went to start it and theres no spark. Only thing I've done is just put a new battery in it . Does the MSD box have an internal fuse which may have blown, or is it likely to be something else!
mel-mike, Jan 21, 8:33pm
Have you had the unit running before!No internal fuse.Check out msd's website,they have a good troubleshooting section.
sydney3, Jan 21, 10:10pm
tell me you didnt put the battery in wrong way around !
pollymay, Jan 21, 11:22pm
Mine did this intermittently even when driving along then would magically fix itself 4minutes to a week later (convenient I know). I landed up buying a new one cause I never figured out why it did it.
paddyman, Jan 25, 6:57pm
Na didnt put battery in back to front, have checked the box and coil and have got plenty of spark there but doesnt seem to be getting to the dizzy or from the dizzy to the leads.
extrayda, Jan 25, 7:28pm
How do you know you have 'spark at the coil' !
If the coil is working, then surely the issue would be with either the HT leads, or the dizzy! Did you touch any of the distributor wiring!
paddyman, Feb 11, 5:12am
Done the MSD test on there website, coil and box are fine.
