V6 commerdore
lilybing1, Mar 5, 6:52pm
coolant pressurising in radiator and blowing into header tank.losing about 1 litre every 4 days just round town,got hot once had radiator and cap checked guessing blown head gasket is there any way offinding out which side!or any other ideas.
franc123, Mar 5, 6:54pm
not without conducting a cylinder leak test, no.
lilybing1, Mar 5, 7:12pm
cap pressure tested and radiator cleaned by rad shop not getn hot now how would a thermostat create a pressure issue!
franc123, Mar 5, 7:19pm
It can if it is causing overheating and thus the coolant to go above boiling point.What model is it!I have had VX series 3.8's around the 2001 era given to me with similar symptoms that have cracked heads, a couple of them now.Not saying its a common problem but it does happen.
richardmayes, Mar 5, 7:25pm
Faulty thermostats won't open, therefore hot water can't circulate out of the engine into the radiator, so it stays in the engine and the whole thing gets hotter and hotter. But the volume of water-filled space inside the waterways remains the same, so the pressure increases until something breaks!
lilybing1, Mar 5, 8:12pm
yea but it is not getn hot.
jmma, Mar 5, 8:19pm
Don't thermostats usually fail safe! eg fail open
ralphdog1, Jun 19, 3:51am
Tell us more about this once
How hot, what actually happened, what were you doing, how far did it get driven while hot etc etc
