Lucas alternator new regulator problem
ginga4lyfe, Apr 14, 6:53pm
the warning light gets connected to the outer slip ring bush, and the reg also connects to that same bush, the black wire goes to body/ground, your old 3 wire would have connected to the other bush, but that is no longer needed, the other bush just connects to the rectifier's last plate , hope that makes sense, or. that could be wrong, the bush closest to the regulator has a plate that gets attached between the reg body and the plastic sace that holds the bushes, so the reg wire may be connected to the other bush! I just cant remember right now.
ginga4lyfe, Apr 14, 7:01pm
http://www.mk1.connectfree.co.uk/nzalternatorrepair/alt1g.GIF HA! I found it! have a look here, the wires that you dont have you done need to worry about
bigfatmat1, Oct 29, 4:51pm
do they only have bushes in viking land ginga no brushes
as above but orange connects to the brush thats notconnected to earth not the bush lol and yellow goes onto w/l terminal of rectifier black to earth while ya at it replace the rectifier they are always stuffing out
