Pin holes in the fuel tank!
sandyelmo, Apr 5, 10:26am
I have a xf ute that I am restoring and I removed the fuel tank on the weekend to rust kill under the deck, as i wire brushed the fuel tank I have noticed a few pin holes on the bottom, any suggestions for the best way to fix this,
clark20, Apr 5, 10:28am
Yes,get a new (2nd hand) tank, if it is thin enough for pinholes the rest won't be good
thejazzpianoma, Apr 5, 10:32am
+1 Given what it is surely there are loads of good tanks around for next to nothing. Could be well worth using a good fuel tank sealer before you put the replacement in too, especially if its been sitting a while. Do it while the tank is out so you can slosh it around easily.
restosupplies.co.nz or POR15 probably have a really good tank sealer.
sandyelmo, Apr 5, 10:43am
Oh ok thanks guys the rest of the tank seems fine, it was bubbled rest spots that turned into pinholes when I wire brushed it, will the tank sealer not seal the pin holes!
bigfatmat1, Apr 5, 3:42pm
vent the tank clean it prep the surface get the gas torch out solder it and use a tank sealer. This is how the radiator place did myne
fordcrzy, Apr 5, 5:04pm
you can get a tank liner paint stuff for motorbike tanks that you put inside the tank and slosh it around and it forms a skin on the inside of the tank and seals it.
unideck, Apr 5, 7:20pm
Its called Kreem but not a cheap option. If $$$ is an issue then Devcon have a top of the range product, its 2k and once set its totally permanent ie you will need a grinder to shape it ;)
Probably best way is to just grab a secondhand one as above.
roys351, Oct 2, 8:10pm
good luck finding a good tank for a xf ute try xh xg at least they are a bit newer
