Battery lights flickering
fordzfly, May 21, 4:40pm
What would cause battery light flickering on hj holden! Battery charging fine at 14v.
alltorque350, May 21, 4:51pm
Loose fan belt!
kenw1, May 21, 4:59pm
dodgy brushes!
fordzfly, May 21, 5:02pm
Its pretty tight. Its the temp and alt light flickering dully when engines running. and then when i pull the handbrake on that light flickers opposite to the alt and temp light.
jmma, May 21, 5:37pm
Best you let us know what you ended up doing, re alternator (o:
fordzfly, May 21, 5:51pm
car hasnt been on the road since god knows when. has a good running 202 from a hq put in it. so all ive done is wired in a external reg from repco.
