Toyota Hilux surf 4wd selecter
patrick.., Jun 10, 4:55pm
Just brought a 89 surf withe the push button 4wd on the hi lo selecter when pushing the button can hear it click underneath and a relay or somthing click up front but it doesnt engage 4wd, the front drive shaft will not spin and the 4wd light isnt up on the dash. help please
mugenb20b, Jun 10, 4:59pm
Has it got manual locking hubs!
grangies, Jun 10, 5:00pm
89 or 99!
patrick.., Jun 10, 5:04pm
Yea it 89 must be the first with the push button stuff, auto hubs
patrick.., Jun 10, 5:09pm
well it has electric hubs that are ment to lock with the button, the button is ment to activate the transfer case and lock the hubs but the transer case isnt even getting the power into the front driveshaft
patrick.., Jun 10, 5:33pm
krieghoff, Jun 10, 5:42pm
Unless you have manual hubs then they are permantly engaged and the process of activating the "4WD" button simply brings the front diff in. Try engaging drive and reverse quickly to see if the front diff will lock.
gadgit3, Jun 10, 6:33pm
The actuator on the transfer case in not working . could be faulty motor or broken spring. Normally it's the motor seized up.
gadgit3, Jun 10, 6:38pm
Oh and the 4WD system has two actuators. One on the diff to en-gauge/dis-en-gauge the RH axle via a dog gear. And the other on the back of the transfer box to do the same via a dog gear on the front drive shaft output.
The front diff one is vac operated and the transfer one is an electric motor that loads up a spiral spring.
steve312, Jun 10, 6:39pm
I would be going with a faulty shift motor too.They are located on the rear of the transfer box.Easy enough to remove and test.
patrick.., Jun 11, 4:18am
Sweet as, Thanks
