i have just got a new ignition today anyonehow to put them back in!
typhoon666,
Jun 6, 7:03pm
what year,model,motor size.
skin1235,
Jun 6, 7:04pm
this is for a 2011 clubsport, or an FJ!, different sized hammers for each model
jurseygurl,
Jun 6, 7:06pm
1997 vt v6
realtrader1,
Jun 6, 7:09pm
Hi everyone.I have just got a new ignition (SWITCH!) today for my.(MAKE).(MODEL).- .(YEAR).(ENGINE/CHA- SSIS NO.).I AM REPLACING THE OLD ONE BECAUSE.Does anyone know how to (TAKE OUT THE OLD ONE AND PUT THE NEW ONE IN!)Thanks in advance!
skin1235,
Jun 6, 7:10pm
and this is a new barrel and key you have purchased! reason I ask is it is not that uncommon for thieves to carry a few spare barrels, especially when out to fulfil an order for say oh a vt holden best bet would be to drop it into a holden dealer for an hour
skin1235,
Jun 6, 7:12pm
now don't get upset by the above, you really don't want us to describe in detail how to remove the barrel and replace it with one of your own, knowing that as we describe it toy you others not so nice maybe reading as well
jurseygurl,
Jun 6, 7:14pm
yes i got new ignition and a key today. i cant get it in to my holden dealer as i have got the old barrel out and the new one sitting on my bench i am asking this question as i am a female and am wanting to put my barrel back in my car as my husband is away for 2 weeks and now i have no vechile!
Jun 6, 7:17pm
Installation is usually done in reverse order of removal.
Jun 6, 7:18pm
That's easy, go to the bench and pick up the new barrel and take it to a Holden dealer. If you are an AA member, give them a ring, they may be able to assist.
jurseygurl,
Jun 6, 7:22pm
thanks skin1235 ill try look online for more advice
skin1235,
Jun 6, 7:22pm
earlier ones used a single pin with the key in acces position to lock the barrel in, you found a way to depress that pin to remove it, reverse order to put it back, make sure you get the slot way in the back aligned or it won't go in properly
soph001,
Jun 7, 11:12am
To remove the old one you would have turned the key to accessories, then poked something down a hole facing the driver, and it would have slid out.
I suggest you turn the new ignition barrel to accessories position until the little spring loaded thing can be pushed down, and slide the barrel in.
This is how it is done properly, without knowing how much damage was done removing the original one, it's hard to guide any further.
Btw, NOW before you put the new one in is the time to get a locksmith to make it match your existing key.
